How to set ESP32 reset when there's crash issue like stack overflow?
mehmet64
Has thanked: 8 times
Been thanked: 4 times
Post by mehmet64 »
hello
how set panic handler behavior in ESP32////
my project with ESP32 crash after 4 or 5 hour in working how can set self restart it
Has thanked: 773 times
Been thanked: 833 times
Re: How to set ESP32 reset when there's crash issue like stack overflow?
Flowcode has an autosave function that can be enabled within Global settings > Application tab
Has thanked: 470 times
Been thanked: 700 times
Post by chipfryer27 »
I think mehmet64 might be meaning when his hardware crashes?
I don't have too much experience with the ESP32 but perhaps the Watch Dog Timer would assist?
Has thanked: 635 times
Been thanked: 842 times
When you say it's crashing what exactly is happening. Emg. Does the WiFi comms stop working etc? Could you do something like trying to detect the stalled condition and for example disconnect and reconnect the WiFi.
chipfryer27 wrote:
Fri Mar 17, 2023 4:56 pm
Yes, indeed.
Thank you I had misread the post.
Has thanked: 177 times
Been thanked: 1016 times
Post by mnfisher »
I posted a small component that allows you to query the restart reason at viewtopic.php?f=3&t=1623&p=9450&hilit=E ... tart#p9450
You can then choose different actions after crash or power on etc.
Need to check why you're getting a crash ? Stack overflow shouldn't occur - do you have some recursive code with no 'end' condition?
