hello
how set panic handler behavior in ESP32////
my project with ESP32 crash after 4 or 5 hour in working how can set self restart it
How to set ESP32 reset when there's crash issue like stack overflow?
mehmet64
- Has thanked: 8 times
- Been thanked: 4 times
- Has thanked: 772 times
- Been thanked: 833 times
Re: How to set ESP32 reset when there's crash issue like stack overflow?
Flowcode has an autosave function that can be enabled within Global settings > Application tab
- Has thanked: 470 times
- Been thanked: 699 times
I think mehmet64 might be meaning when his hardware crashes?
I don't have too much experience with the ESP32 but perhaps the Watch Dog Timer would assist?
- Has thanked: 635 times
- Been thanked: 842 times
When you say it's crashing what exactly is happening. Emg. Does the WiFi comms stop working etc? Could you do something like trying to detect the stalled condition and for example disconnect and reconnect the WiFi.
Yes, indeed.chipfryer27 wrote: ↑Fri Mar 17, 2023 4:56 pmHi
Thank you I had misread the post.
- Has thanked: 177 times
- Been thanked: 1016 times
I posted a small component that allows you to query the restart reason at viewtopic.php?f=3&t=1623&p=9450&hilit=E ... tart#p9450
You can then choose different actions after crash or power on etc.
Need to check why you're getting a crash ? Stack overflow shouldn't occur - do you have some recursive code with no 'end' condition?
