have a problem with Bluetooth HC05 in FC10
In FC9 it works in FC10 the compiler aborts.
the initialisation is already enough
Target folder: C:\Users\uwe\Documents\Daten\Flowcode 10
Source name: C:\Users\uwe\Documents\Daten\Flowcode 10\HC05.fcfx
Title:
Description:
Device: PIC.18F.18F26K80
Generated by: Flowcode v10.0.1.18
Date: Friday, March 17, 2023 17:25:52
Users: 1
Registriert für: SpeedPic32 (24146314)
Lizenzschlüssel:H7PVJQ
https://www.flowcode.co.uk
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Start des Compilers...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Compilers\picv2\" 18F26K80 "C:\Users\uwe\Documents\Daten\Flowcode 10\" "HC05"
C:\Users\uwe\Documents\Daten\Flowcode 10>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589C569E919D18CE8A1A34BBBAC3833A58DC4965B289802A73C711B8143522C2B69111B4A5DDD1F78C950CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE62F7CFE01D097A864378D9A0E5EA102BCFFF841E91EDD344372B6BE213A82E53320EB63F877F4A9A
C:\Users\uwe\Documents\Daten\Flowcode 10>REM REVISION: 2.0
C:\Users\uwe\Documents\Daten\Flowcode 10>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Users\uwe\Documents\Daten\Flowcode 10>REM DATE: 02\03\2023
C:\Users\uwe\Documents\Daten\Flowcode 10>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Users\uwe\Documents\Daten\Flowcode 10>"C:\Program Files (x86)\Flowcode\Compilers\picv2\bin\xc8-cc.exe" -mcpu=18F26K80 "HC05.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
HC05.c:8306:1: error: (984) type redeclared
HC05.c:8306:1: error: (1098) conflicting declarations for variable "FCD_0fc51_gLCD_SSD1306__PrintNumber" (HC05.c:8305)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat Hat den Fehlercode 0x1 gemeldet
Autoclose turned off
BEENDET
HC05
SpeedPIC32
- Has thanked: 49 times
- Been thanked: 20 times
- Has thanked: 478 times
- Been thanked: 713 times
Re: HC05
I noticed you have your display on PortA but also your Pot on AN0 (porta0).
I moved Pot to an unused pin but the issue still persists.
However your chart only initialises the display, nothing more, and when you remove the display it then compiles to Hex, so it looks related. Possibly a bug?
SpeedPIC32
Re: HC05
I have tested it in the same way. When INI is removed from the display or Bluetooth, I can compile. as soon as I add it again, the error occurs.
in FC9 the same file compiles fine so I can use all four components. When I load it, I only get the message that it was created with a newer version.
ÄFCÄ9 or FC10 With kind regards
- Has thanked: 795 times
- Been thanked: 858 times
Re: HC05
Can you try the attached project file in v10
- HC05 FC10.fcfx
- (17.37 KiB) Downloaded 608 times
- (view online)
Re: HC05
As the display uses I2C which has Ch-1 SDA/SCL on Port-C 3/4 and the FileSD uses SPI which also has Ch-1 CLK/MISO on Port-C 3/4 you will need to use a Software alternative for one of them.
Unfortunately I've never had to implement Software channels so I can't really give much advice on which of the above would perform better on a Software channel.
SpeedPIC32
Re: HC05
I just rebuilt the project with another PIC. Again there is the same problem with the I2C GLCD SSD1306 module.
It does not compile. Always the same error
Target folder: C:\Users\uwe.kapuschinski\Documents\Flo
Source name: C:\Users\uwe.kapuschinski\Documents\Flo\Flowcode2.fcfx
Title:
Description:
Device: PIC.18F.18F27K40
Date: Thursday, March 23, 2023 10:00:44
Users: 1
Registered to: SpeedPic32 (24146314)
Licence key: ZQ34CT
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\" 18F27K40 "C:\Users\uwe.kapuschinski\Documents\Flo\" "Flowcode2"
C:\Users\uwe.kapuschinski\Documents\Flo>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589C569E919D18CE8A1A34BBBAC3833A58DC4965B289802A73C711B8143522C2B69111B4A5DDD1F78C950CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE62F7CFE01D097A864378D9A0E5EA102BCFFF841E91EDD344372B6BE213A82E53320EB63F877F4A9A
C:\Users\uwe.kapuschinski\Documents\Flo>REM REVISION: 2.0
C:\Users\uwe.kapuschinski\Documents\Flo>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Users\uwe.kapuschinski\Documents\Flo>REM DATE: 02\03\2023
C:\Users\uwe.kapuschinski\Documents\Flo>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Users\uwe.kapuschinski\Documents\Flo>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8-cc.exe" -mcpu=18F27K40 "Flowcode2.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
Flowcode2.c:7952:1: error: (984) type redeclared
Flowcode2.c:7952:1: error: (1098) conflicting declarations for variable "FCD_0cc51_gLCD_SSD1306_i2c1__PrintNumber" (Flowcode2.c:7951)
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
FINISHED
I put the error again new
Thanks a lot
Title:
Description:
Users: 1
Licence key: ZQ34CT
FINISHED
Thanks a lot
