HC05
SpeedPIC32
Has thanked: 49 times
Been thanked: 20 times
Flowcode v10 HC05
Post by SpeedPIC32 »
have a problem with Bluetooth HC05 in FC10
In FC9 it works in FC10 the compiler aborts.
the initialisation is already enough
Target folder: C:\Users\uwe\Documents\Daten\Flowcode 10
Source name: C:\Users\uwe\Documents\Daten\Flowcode 10\HC05.fcfx
Title:
Description:
Device: PIC.18F.18F26K80
Generated by: Flowcode v10.0.1.18
Date: Friday, March 17, 2023 17:25:52
Users: 1
Registriert für: SpeedPic32 (24146314)
Lizenzschlüssel:H7PVJQ
https://www.flowcode.co.uk
Using <PICkit2 PK2CMD External Power> inbuilt settings for compiler
Start des Compilers...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Compilers\picv2\" 18F26K80 "C:\Users\uwe\Documents\Daten\Flowcode 10\" "HC05"
C:\Users\uwe\Documents\Daten\Flowcode 10>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589C569E919D18CE8A1A34BBBAC3833A58DC4965B289802A73C711B8143522C2B69111B4A5DDD1F78C950CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE62F7CFE01D097A864378D9A0E5EA102BCFFF841E91EDD344372B6BE213A82E53320EB63F877F4A9A
C:\Users\uwe\Documents\Daten\Flowcode 10>REM REVISION: 2.0
C:\Users\uwe\Documents\Daten\Flowcode 10>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Users\uwe\Documents\Daten\Flowcode 10>REM DATE: 02\03\2023
C:\Users\uwe\Documents\Daten\Flowcode 10>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Users\uwe\Documents\Daten\Flowcode 10>"C:\Program Files (x86)\Flowcode\Compilers\picv2\bin\xc8-cc.exe" -mcpu=18F26K80 "HC05.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
HC05.c:8306:1: error: (984) type redeclared
HC05.c:8306:1: error: (1098) conflicting declarations for variable "FCD_0fc51_gLCD_SSD1306__PrintNumber" (HC05.c:8305)
(908) exit status = 1
Error returned from [xc8.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat Hat den Fehlercode 0x1 gemeldet
Autoclose turned off
BEENDET
HC05.fcfx
(17.33 KiB) Downloaded 530 times
Has thanked: 425 times
Been thanked: 646 times
Re: HC05
I noticed you have your display on PortA but also your Pot on AN0 (porta0).
I moved Pot to an unused pin but the issue still persists.
However your chart only initialises the display, nothing more, and when you remove the display it then compiles to Hex, so it looks related. Possibly a bug?
Re: HC05
I deleted the display as per above, then added it back and it compiled to Hex without issue. Just a guess that perhaps FC got messed up somehow?
SpeedPIC32
Flowcode v10 Re: HC05
I have tested it in the same way. When INI is removed from the display or Bluetooth, I can compile. as soon as I add it again, the error occurs.
in FC9 the same file compiles fine so I can use all four components. When I load it, I only get the message that it was created with a newer version.
ÄFCÄ9 or FC10
HC05.fcfx
(17.33 KiB) Downloaded 507 times
With kind regards
Has thanked: 695 times
Been thanked: 767 times
Re: HC05
Can you try the attached project file in v10
HC05 FC10.fcfx
(17.37 KiB) Downloaded 545 times
SpeedPIC32
Re: HC05
hello medelec35
it works
what was changed? What was the problem?
Many thanks
greetings SpeedPic32
Re: HC05
chipfryer27 gave the correct information.
He deserves the credit.
I just replaced the display with the same type.
SpeedPIC32
Re: HC05
I need the I2C display
I have only 4 connections on the display
DEBO_OLED_0-96_DB-EN.pdf
(177.41 KiB) Downloaded 593 times
Re: HC05
As the display uses I2C which has Ch-1 SDA/SCL on Port-C 3/4 and the FileSD uses SPI which also has Ch-1 CLK/MISO on Port-C 3/4 you will need to use a Software alternative for one of them.
Unfortunately I've never had to implement Software channels so I can't really give much advice on which of the above would perform better on a Software channel.
SpeedPIC32
Re: HC05
I just rebuilt the project with another PIC. Again there is the same problem with the I2C GLCD SSD1306 module.
It does not compile. Always the same error
Target folder: C:\Users\uwe.kapuschinski\Documents\Flo
Source name: C:\Users\uwe.kapuschinski\Documents\Flo\Flowcode2.fcfx
Title:
Description:
Device: PIC.18F.18F27K40
Date: Thursday, March 23, 2023 10:00:44
Users: 1
Registered to: SpeedPic32 (24146314)
Licence key: ZQ34CT
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat "C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\" 18F27K40 "C:\Users\uwe.kapuschinski\Documents\Flo\" "Flowcode2"
C:\Users\uwe.kapuschinski\Documents\Flo>REM CRC: 90CF26913586BBA787FE92D553771933222DCF72B25FEB4608E17FBD060500D8A6D7AF8357042D9E8B5C2E833010A32BE2214988CBC1BB00301ECF6745983589C569E919D18CE8A1A34BBBAC3833A58DC4965B289802A73C711B8143522C2B69111B4A5DDD1F78C950CACCEB0B5A8E521002EAF3D15174CD20633AD186EC562DBEEF6112EA5AA5CF5041CCE14E8D252BC416ECB8EC7761E4FD518969900F56C6C8F36CE7BEFFD91E73F563CBE7F64B8A69F01B3F3C0F45102C3050DA273BE4EE62F7CFE01D097A864378D9A0E5EA102BCFFF841E91EDD344372B6BE213A82E53320EB63F877F4A9A
C:\Users\uwe.kapuschinski\Documents\Flo>REM REVISION: 2.0
C:\Users\uwe.kapuschinski\Documents\Flo>REM GUID: 50CB4B58-ED9C-4591-8D65-A87DE810E8CC
C:\Users\uwe.kapuschinski\Documents\Flo>REM DATE: 02\03\2023
C:\Users\uwe.kapuschinski\Documents\Flo>REM DIR: FCD\PIC\batch\pic_xc8_comp.bat
C:\Users\uwe.kapuschinski\Documents\Flo>"C:\Program Files (x86)\Flowcode\Common\Compilers\picv2\bin\xc8-cc.exe" -mcpu=18F27K40 "Flowcode2.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
Flowcode2.c:7952:1: error: (984) type redeclared
Flowcode2.c:7952:1: error: (1098) conflicting declarations for variable "FCD_0cc51_gLCD_SSD1306_i2c1__PrintNumber" (Flowcode2.c:7951)
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC\batch\pic_xc8_comp.bat reported error code 0x1
FINISHED
I put the error again new
Thanks a lot
