hello
how can i compile the C code generated with flowcode in MPLAB i know is possible but i cant do that?
C code compiling in mplab
mehmet64
- Has thanked: 8 times
- Been thanked: 4 times
- Has thanked: 615 times
- Been thanked: 807 times
Re: C code compiling in mplab
It should be possible to take the Flowcode C and H files and compile them in MPLAB on a PC that has Flowcode installed. There are various library CAL files that the C and H file will access but as long as on the same PC then it all should work.
What errors are you getting in MPLAB?
yes i know but mplab dont compile it ........
i attached this
i attached this
- MPLAB ERR.txt
- (14.72 KiB) Downloaded 587 times
- Has thanked: 289 times
- Been thanked: 453 times
Please post your *.fcfx project file, or better still a simple project that also has this issue, and we will investigate.
Thinking further on this, you could try replicating the XC8 switches used by Flowcode as much as possible when compiling via MPLAB. For example, Flowcode uses "-std=c90" whereas your MPLAB compilation attempt uses "-std=c99" and that could be the setting that is causing the problem.
For STM32 projects, the compilation process is more complex. Flowcode uses the GCC compiler toolchain and uses a batch file (stm32comp.bat) to perform the numerous compilation steps. You may be able to replicate this through a different IDE, but that is something we can't help with.
