C code compiling in mplab
mehmet64
Has thanked: 8 times
Been thanked: 4 times
Post by mehmet64 »
hello
how can i compile the C code generated with flowcode in MPLAB i know is possible but i cant do that?
Has thanked: 593 times
Been thanked: 780 times
Re: C code compiling in mplab
It should be possible to take the Flowcode C and H files and compile them in MPLAB on a PC that has Flowcode installed. There are various library CAL files that the C and H file will access but as long as on the same PC then it all should work.
What errors are you getting in MPLAB?
mehmet64
Post by mehmet64 »
yes i know but mplab dont compile it ........
i attached this
MPLAB ERR.txt
(14.72 KiB) Downloaded 566 times
Has thanked: 268 times
Been thanked: 432 times
Please post your *.fcfx project file, or better still a simple project that also has this issue, and we will investigate.
Thinking further on this, you could try replicating the XC8 switches used by Flowcode as much as possible when compiling via MPLAB. For example, Flowcode uses "-std=c90" whereas your MPLAB compilation attempt uses "-std=c99" and that could be the setting that is causing the problem.
mehmet64
Post by mehmet64 »
hello Steve
i change it to C90 and it working well thank you
and about STM32 C code how can copile this C code and i shuold use how IDE for it
For STM32 projects, the compilation process is more complex. Flowcode uses the GCC compiler toolchain and uses a batch file (stm32comp.bat) to perform the numerous compilation steps. You may be able to replicate this through a different IDE, but that is something we can't help with.
