ESP32 Espressif Compiler Failure
nmjb18
Has thanked: 10 times
Been thanked: 1 time
Post by nmjb18 »
I am attempting to compile a program to an ESP32 for the first time using FCv10 and have encountered the error:
"ERROR: C:\Espressif\python_env\idf5.0_py3.7_env\Scripts\python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument."
Help interpreting and fixing this issue would be much appreciated.
Thanks,
Matt
Has thanked: 435 times
Been thanked: 651 times
Re: ESP32 Espressif Compiler Failure
Post by chipfryer27 »
Another user had a similar problem using v9 here
viewtopic.php?p=11126#p11126
Hope this helps
nmjb18
Post by nmjb18 »
Thanks Chipfryer27, appreciate the tip. I will review tonight and report back.
Cheers,
nmjb18
Post by nmjb18 »
I followed the above referenced thread and the additional linked thread. Tried all the suggestions and still have the same issue.
Further support would be gratefully received.
Rgds
Has thanked: 713 times
Been thanked: 775 times
Have you read this post?
nmjb18
Post by nmjb18 »
I haven't and will try over the weekend, it looks promising, thanks for link.
nmjb18
Post by nmjb18 »
The instruction in the above linked post worked for me. Thank you for your help.
You're welcome.
Thank you for letting us know.
