I am attempting to compile a program to an ESP32 for the first time using FCv10 and have encountered the error:
"ERROR: C:\Espressif\python_env\idf5.0_py3.7_env\Scripts\python.exe doesn't support asyncio. The issue can be worked around by re-running idf.py with the "--no-hints" argument."
Help interpreting and fixing this issue would be much appreciated.
Thanks,
Matt
ESP32 Espressif Compiler Failure
nmjb18
- Has thanked: 10 times
- Been thanked: 1 time
- Has thanked: 478 times
- Been thanked: 713 times
Re: ESP32 Espressif Compiler Failure
Another user had a similar problem using v9 here
viewtopic.php?p=11126#p11126
Hope this helps
Hope this helps
I followed the above referenced thread and the additional linked thread. Tried all the suggestions and still have the same issue.
Further support would be gratefully received.
Rgds
Rgds
