Thanks Chipfryer27 for the recap. I am also indebted to Martin (and not just for this one).
I did remove all stray folders and files I could find that remained after the uninstall.
I did not run the registry cleaner, nor did I do the install as Admin.
I will try that next.
Which reg cleaner did you use?
Jan
ST7789 display
jandidden
- Has thanked: 28 times
- Been thanked: 12 times
- Has thanked: 478 times
- Been thanked: 712 times
- Has thanked: 177 times
- Been thanked: 1026 times
Re: ST7789 display
Thanks to Iain for testing this - I'd been starting to have doubts about the install. Had I missed a/the 'vital' step out.
The toolset does seem a little 'fragile' with it's many dependencies - and I've spent many 'happy' hours installing and reinstalling it in the past. For a long time - I ran it off a USB memory stick, as that was the only version I had that worked and it resisted all attempts to get it to work from my hard-drive. The registry cleaner is a good idea - and possibly removing 'old' paths from windows' environment paths?
Re: ST7789 display
I have another W10 exact same as before.
This morning I :-
Uninstalled Python
Uninstalled Git
Uninstalled ESP
Manually removed ESP / Git folders
Ran Registry Cleaner
Rebooted
Ran Registry Cleaner (note: it is a good idea to keep re-running registry cleaners until no further issues appear)
Installed as per Martin's post running each as administrator. I checked enable path and also enabled Python to use file names longer than 250 characters. I don't recal doing that yesterday.
Ran FC v10.0.2.21 and did a full database update
Changed FC to look for ESP as per Martin's post
Created a small chart for an ESP32-WROOM
Compiled to Hex without issue
Changed chart to use an ESP32-S2
Perhaps Martin might like to repost in another section or start a new thread, as finding such a helpful post in a "Display" issue may not reach everyone. As mentioned posts concerning ESP installs are rather fragmented at present so I personally think it would be helpful to make it more visible.
I also appreciate the work done by Matrix too and understand the ESP's on v5 are still work in progress. I will be using the S2 variant later in the week and will update with any issues found.
Hope the above is helpful to someone.
This morning I :-
Uninstalled Python
Uninstalled Git
Uninstalled ESP
Rebooted
Re: ST7789 display
I performed the actions as shown in the attached text file. At the end I got stuck at setting the esp path in FC10 with the error: 'only allowed on professional version'.
I have the licensed version of FC10 installed, I have been a professional user since a decade or so, not sure what I am missing.
Have not installed as administrator yet. Would like to get past the path setting thing, if then still fails, I'll redo the whole shebang as admin.
Did set the path in FC9 and ran that, getting the familiar ninja fail message.
Jan
Jan
- installing ESP32 toolchain.txt
- (1.88 KiB) Downloaded 621 times
Re: ST7789 display
Not really sure about that. I changed location in File> Global Options > Locations using the Browse button (three dots) to the right of the ESP Toolchain. I didn't use the "Customise" button in the build ribbon.
