MPU-6886 adress (0x68) OK / (0x69) NOT OK
Has thanked: 246 times
Been thanked: 258 times
The MPU6886 is working nice with the adress 0(0x68)
But NOT with the adress 0(0x69) (and hardware change pin A0)
Re: MPU-6886 adress (0x68) OK / (0x69) NOT OK
So if I use only one IMU, that's ok
Adress 0(0x69) with A0 GND works
Adress1(0x69) with A0 3v3 works
unfortunately I need both IMU
There is already a problem with initialising
This program does not run, it hangs on the second test.
no matter if address 0 or 1 first
hang on second test:
Flowcode v10 Re: MPU-6886 adress (0x68) OK / (0x69) NOT OK
I prepared 4 IMU
2pcs with adress 0x68
2pcs with adress 0x69
I tested individually on bus1 and all of these work well.
So I connected them all on bus1 and bus2 and this is not working
but if I connect one module to bus1 and the other to bus2, it works no matter which address I use.
Only one module works on one bus!
(of course I have always adjusted the addresses and pins)
My hardware has 2 groove connector, but soon I have to connect it to a smaller hardware with only one i2c bus free
Has thanked: 647 times
Been thanked: 856 times
Hi Stefan,
Is it an ESP you're using? I think I might need to make a similar mod like I did to the ESP32 SPI CAL.
Yes it's an ESP32 now and later.
OK thanks, I'll look into doing the mod for you this afternoon.
Right I've pushed a change and checked it compiles ok. Hopefully this should now allow multiple components to share the same ESP32 I2C hardware channel.
Let me know how you get on.
I tested two modul on the same bus and now it's working perfect!
thank's alot
