UNO SCADA SPI Prescaler question
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Post by p.erasmus »
Hi Team.
From the UNO SCADA help file the values for the SPI prescaler range from 0 -2 (0,1,2)
Can you guys please help me if the UNO Clock frequency is 16MHZ what will the SPI Clock then be if we use
0, = ?
1, = ?
2, = ?
prescaler
Thanks for helping out
:D
Has thanked: 163 times
Been thanked: 960 times
Re: UNO SCADA SPI Prescaler question
Post by mnfisher »
The documents aren't very clear?
I'd guess the values correspond to prescaler of 4, 16, and 64 (ie clock of 16Mhz (FOsc?) / prescale) - the firmware calls SetPrescaler in the CAL SPI. (Docs don't specify here either)
Edit - however experimenting in v8 (see below) - calling SetPrescaler with (2,4,8 etc) gives the expected results (at least in software mode).
Some problems:
I tested on a Nano - and the default CS pin for hardware mode is incorrectly set to C2 (instead of B2) -
Hardware mode didn't work on a very basic program..
Master_init
Loop
Master_Byte(123)
end loop
Tested using v8 (so I can upload) - and this works in software mode only (I just look at the CLK on D13 on the oscilloscope)
In V9:
After upgrading the Nano def file - uploading fails
H:\>"H:\AVR\avrv5\batchfiles\..\bin\avrdude.exe" -p m328p -P 57600 -b "H:\spi test.hex" -c arduino -D -U flash:w:""
avrdude.exe: invalid baud rate specified 'H:\spi test.hex'
- The command line argument for avrdude is now messed up (should be -b (baud rate) 57600 - NOT -P 57600 -b file...)
p.erasmus
Post by p.erasmus »
Martin,
Thanks for the info,
However this Baud problem isn't it part of my problem on the Chinese UNO( as I mentioned the supplier settings mention 57600 ,I cannot judge this never worked with AVR and its tools, component simulation forced me to use the UNO for many reasons,
viewtopic.php?f=3&t=203
Example if I use the ARDUINO IDE I can connect to the Chinese UNO and program it ,from V9 it is not possible to program from V9 ,but then again confusing me ,a Genuine Arduino UNO I have no problems with programming from V9 and use in HW SCADA simulation however this was with I2C ,will see now with SPI :D :D
Post by mnfisher »
Hi Peter,
Have you tried loading the newer bootloader onto the clone Uno?
See https://www.instructables.com/How-to-Up ... 0to%20Nano
For example?
p.erasmus
Post by p.erasmus »
Martin.
I still did not do that because of time and afraid to mess around with my new UNO ,costing a fortune if you pay with my country's exchange rate :o
I will probably try it once I have done what I want with the SCADA Simulation as I have to make one UNO to a Programmer by loading new SW on it and then program the other one a risky thing for a PIC user on a AVR :D
Thanks for the link will do that asap
Post by mnfisher »
I just re-flashed a clone Nano - using a USB Tiny.. Much nicer working at 115200 :)
But - no the baud rate shouldn't affect the SPI (and see new edit above about the 0,1,2)
I've added a bug report about that...
Something not quite right with the SPI on the AVR chips. I've put bug reports about the USI implementation (in the old forum) - but have had problems with the hardware implementation on Arduino before :-( Maybe I do something wrong??
p.erasmus
Post by p.erasmus »
Thanks for all the help Martin,
If things improve in future I will order a ECIO28P as I like to work with PIC's and the reason is I understand their inner workings and have no idea of ATMEL so easier for me to carry on with PIC :D ,It is so easy to work with the SCADA Simulation in testing and developing interfaces
Post by mnfisher »
Thanks for giving us a pointer on this - it was interesting, I've not really used SCADA, to see how useful it can be!
Will have to have a more in depth play when time allows...
p.erasmus
Post by p.erasmus »
mnfisher wrote:
Sat Feb 20, 2021 7:38 pm
Hi Martin ,
I am running SPI on the UNO Scada ,I see no issue with the SPI it is working fine for me at least at the moment
:D :D
Post by mnfisher »
Hi Peter,
The problem - the hardware mode on USI gives no signal. (Implementation uses MOSI (which label refers to connection for programmer such as USBTiny) - but needs to use DOUT which on ATTiny 85 is d1 and not d0.
I've occasionally hit a problem where there is no signal on MOSI on Arduino - and nothing works until the program 'hits' a certain size. Or something changes - I've never managed to quite pin down what the problem is - but like the example in previous message - software mode works AOK but no signal on hardware mode..
What effect did you get with the prescaler values??
