with the PIC16F1829 the INT pin does not work. Port interrupt works so far. Also there is an error
in the configuration of the chip. Int OSC is specified with pin A7. There is no pin A7.
Problem with pins on PIC16F1829
DirkB
- Has thanked: 1 time
- Been thanked: 4 times
- Has thanked: 647 times
- Been thanked: 856 times
Re: Problem with pins on PIC16F1829
Many thanks for letting us know, hopefully both issues fixed for you now via the library updates.
