Problem with pins on PIC16F1829
DirkB
Has thanked: 1 time
Been thanked: 4 times
Post by DirkB »
with the PIC16F1829 the INT pin does not work. Port interrupt works so far. Also there is an error
in the configuration of the chip. Int OSC is specified with pin A7. There is no pin A7.
Has thanked: 647 times
Been thanked: 856 times
Re: Problem with pins on PIC16F1829
Many thanks for letting us know, hopefully both issues fixed for you now via the library updates.
DirkB
Has thanked: 1 time
Post by DirkB »
works perfect now, thanks!
Dirk
