Print a flowchart for publication purposes
jandidden
Has thanked: 28 times
Been thanked: 12 times
Post by jandidden »
I'm working on a technical article that will have to include some FC flowcharts.
I was wondering if there is an FC option somewhere to print a flowchart?
I would 'print to PDF' to get pub quality illustrations; screen shots are generally too limited in resolution for that purpose.
Is there some (hidden) function to print a flowchart?
Jan
Has thanked: 246 times
Been thanked: 258 times
Re: Print a flowchart for publication purposes
Hi Jan
Did you see this export and more even a html doc with the charts?
Has thanked: 311 times
Been thanked: 479 times
Flowcharts can be saved as a PNG, JPG or BMP. None of these are vector format. You can improve the quality of the image export by first zooming the view of the flowchart to 200% (the maximum).
jandidden
Post by jandidden »
@stefan.erni, yes that works. The HTML output appears to be vector based (no pixelation when zooming) but I don't see a way to import that into Word. I need to look into that, if possible that would be ideal.
Edit: Yes that works, you can import an HTML into Word, but for some reason a FC comes across at about 60 inch x 60 inch!
Setting the size down to 10% or so makes it manageable.
You can save individual flowcharts but only as .png.
@Steve-Matrix zooming will probably not work for me as the FC already fills the screen as it is. But will look into it.
Jan
steve001
Has thanked: 81 times
Been thanked: 30 times
Post by steve001 »
Hi Jan,
For large images have you tried using Paint 3D to resize it ?
Unfortunately microsoft removed it from windows 11 but you can still download it from microsoft web site.
Autocad inventor outputs where 10000 x 10000 and it handled these with ease. The output can be changed to most image formats also.
https://apps.microsoft.com/store/detail ... BLGGH5FV99
Has thanked: 795 times
Been thanked: 858 times
Hi Jan
if you load the HTML in Chrome, Click on the flowchart you are interested in, it will convert it to a large png. on a separate tab.
Click on the three dots on the top right of Chrome, select Print.
Within Destination, select Save as pdf.
You then have a zoomable pdf file.
Chadb
Has thanked: 32 times
Been thanked: 1 time
Post by Chadb »
If you are on a pc a really great free (as in beer) image viewer and editor is FastStone. Been using it for years. It's awesome.
https://www.faststone.org/FSViewerDetail.htm
Chad
