Power Supply Monitoring Circuit
steve001
Has thanked: 81 times
Been thanked: 30 times
Post by steve001 »
Afternoon All,
Following another post on here that needed to know a low power supply voltage and trigger an event.
This got me thinking .....
I came up with this circuit - please see attached
The incoming supply DC voltage 7 - 9 V DC is monitored and if low the comparator output goes low, this could then be connected to an Interrupt pin on the micro and used to trigger a "Event"
The 3 x 470 uF Capacitors hold up the supply hopefully long enough to the "Event" to take place
This is only a rough and ready test circuit R1 & R2 possibly need looking at at the output went low when the DC input voltage was at around 4.9 V DC
Hope somebody finds this useful
steve001
Re: Power Supply Monitoring Circuit
Post by steve001 »
Noticed last night if anybody wanting to have a go with this i have put the voltage reference in the wrong place
I would normally place it after the voltage regulator
The circuit works on a bread board as described above, R1 & R2 may need adjusting experience shows that voltage dividers on breadboards tend to give incorrect results due to the connections resistance.
I plan to have a further look at this circuit later and draw it up properly.
Edit : Change the 2K2 resistor on the TL431C to 390 Ohms when powered from the 5 Volt Rail
The Resistors i used are MF25 Series From Farnell
Circuit - Copy.jpg (49.46 KiB) Viewed 5272 times
steve001
Post by steve001 »
Afternoon All,
Done a few tests with various capacitors using A PIC16C710 monitoring a DC voltage and turns on or off some transistors to drive a relay (@12V) nothing too spectacular. This current was measured at 3.9mA with a fluke meter. = 0.0195 W.
so using an electronic load in constant Power mode set at 0.02W and a timer circuit to start and stop on a low voltage detect, and disconect the incoming supply. Supplying the various capacitors at varying voltages (Pre Regulator)
1 x 1000uf
Test 1 @ 7.5 Volts
0.32 seconds
Test 2 @ 9 Volts
0.02 W 0.41 seconds
Test 3 @ 12 Volts
0.02 W 0.60 seconds
Test 4 @ 15 Volts
0.02 W 0.87 seconds
2 x 1000uf
Test 5 @ 7.5 Volts
0.36 seconds
Test 6 @ 9 Volts
0.55 seconds
Test 7 @ 12 Volts
0.87 seconds
Test 8 @ 15 Volts
1.27 seconds
3 x 1000uf
Test 9 @ 7.5 Volts
0.50 seconds
Test 10 @ 9 Volts
0.69 seconds
Test 11 @ 12 Volts
1.16 seconds
Test 12 @ 15 Volts
1.66 seconds
4 x 1000uf
Test 13 @ 7.5 Volts
0.64 seconds
Test 14 @ 9 Volts
0.92 seconds
Test 15 @ 12 Volts
1.49 seconds
Test 16 @ 15 Volts
2.10 seconds
1 x 10,000 uf
Test 17 @7.5 Volts
11.69 seconds
Test 18 @ 9 Volts
20.46 seconds
Test 19 @12 Volts
33.56 seconds
Test 20 @ 15 Volts
51.33 seconds
viktor_au
Has thanked: 11 times
Been thanked: 19 times
Post by viktor_au »
Hello Steve
Pls have a look at the schematics I changed.
What do you think?
steve001
Post by steve001 »
Hi Viktor
What do you want it to do / measure ?
The circuit works by comparing 2 x 2.5 volt signals. Vref from the voltage reference and the voltage divider network.
If the non-inverting (+) input is greater than the inverting (-) input the output will be high.
If the inverting input (-) is greater than the non-inverting (+), the output will be low.
I originally made a mistake and put the TL431 before the voltage regulator, this should be after the regulator ideally.
:edit
In normal operation the output is high.
Its not desirable to have circuits energising on faults.
Has thanked: 442 times
Been thanked: 661 times
Post by chipfryer27 »
Hi Viktor
Welcome to the Dark Side (v10 forum colour scheme versus v8).
viktor_au
Post by viktor_au »
Hello Steve, ChipFryer
Re:The circuit works by comparing 2 x 2.5 volt signals. Vref from the voltage reference and the voltage divider network.
steve001
Post by steve001 »
Morning Viktor,
The circuit arrangement is a common arrangement that i used to employ on some battery monitoring boards for deep discharge protection.
This voltage is any where from 48 to 254 V DC this is where the voltage divider came from.
I just used the same input method for ease as i took the supply voltage to 15 Volts (see above tables) and altered the voltage divider to suit.
Edit:
just replied quickly previously, and didn't give it much thought.
Using a voltage divider allows you to better control the operating point of the comparator by setting the divider network to suit your voltage.
