Component: GLCD Graph Creator
stuartwili
Been thanked: 2 times
Post by stuartwili »
i am trying to use Component: GLCD Graph Creator and Component: GLCD XYGraph Creator. so far all i get is compiler errors. there is little or no information on how to use this function. there are no examples to check.
cheers
Stuart
Has thanked: 616 times
Been thanked: 815 times
Re: Component: GLCD Graph Creator
Hi Stuart,
Please can you attach your project so far and I'll investigate the issue for you.
stuartwili
under the User Macro XYgraphcreator i have tried both avaiable graph creators. i have under Creat_Graph have drawn the graph long hand. it would be possibly be easer to use the built in graph creator, if we find out how to use it?
Cheers Stuart
flowcode error.jpg (29.62 KiB) Viewed 3179 times
RPi_Test_3_310723.fcfx
(74.75 KiB) Downloaded 349 times
Many thanks I've now been through and updated the two graph components as they were broken in the latest exe release.
Hopefully all sorted for you now via the Help -> Library updates.
The components should be fairly straightforward now they are working so let us know how you're getting on with them and if you need any additional help or features.
stuartwili
I have updated the component library in flow code. I have deleted all references to previous versions of the graph creator. I have imported from the library new graph creator component. I still get the same error on compile. am I using them incorrectly?
I have attached current version and the error screen is the same as before.
cheers
stuart.
(71.97 KiB) Downloaded 303 times
It's compiling ok for me, did you run the Help -> Library updates?
(71.79 KiB) Downloaded 318 times
stuartwili
i have run the Help->Library updates. I downloaded all updates and restarted flowcode. It now shows no updates available.
Cheers
Stuart
