Help needed GPS calculation!
Has thanked: 772 times
Been thanked: 831 times
Re: Help needed GPS calculation!
Hello, monie.
Have you had a look at the examples on the wiki?
On the 2D panel, right-click and select Help
A window will open and you will see some example projects.
monie
Has thanked: 1 time
Post by monie »
Hello Flowcode user
Have attached file: dsPIC_BL0032_GPS
Does anyone have a Flowcode example of GPS together with dsPIC BL0032-1
Yours sincerely
Monie
dsPIC_BL0032_GPS.fcfx
(19.2 KiB) Downloaded 484 times
Has thanked: 634 times
Been thanked: 842 times
Hi Monie,
Here's a modified example to get you started,
(14.06 KiB) Downloaded 643 times
Click board on Port D, display board on Port BL.
Hopefully should work well for you.
If you're getting nothing out the module then you could try driving pin D7 (reset) high and checking the default baud for the module matches the component baud of 9600.
monie
Has thanked: 1 time
Post by monie »
Hi BenR
Thank you very much for helping me with suggestions to get the dsPIC_BL0032_GPS and LCD (BL0169-1.
But I can't see any (Lat , Long) coordinates in the Display.
See the picture below!
dsPIC_BL0032_GPS_and LCD.jpg (167.2 KiB) Viewed 5109 times
Properties BL032.jpg (82.21 KiB) Viewed 5103 times
I have tried according to your description.
But can't see any coordinates in the display.
I have tried exactly according to your instructions but without success.
Yours sincerely
Monie
monie
Has thanked: 1 time
Post by monie »
Hi BenR
I have not been able to reply to your post until now, as the FORUM and the entire Flowcode website have been shut down.
But your suggestion works fine for me. I also discovered that the cable for the GPS Antenna was defective.
But when using another GPS antenna, your Flowcode coder works very well fine.
Thank you very much for the help:-)
Yours sincerely
Monie
monie
Has thanked: 1 time
Post by monie »
Hello all Flowcode users
I can't find the Programmer Port on the BL0032. Please see below!
Would you be helpful with a suggestion?
BL0032:
User: Eblocks2 dsPIC Programmer BL0032-1
Flowcode Test Menu-001:
Flowcode Test Menu-001.fcfx
(36.63 KiB) Downloaded 643 times
User: Windows v 11
And Flowcode v 10
With best regards
Monie
Hi Monie,
Please can you follow Chipfriers great advice and if you are having problems getting it to work then please can you attach your project file so we can see what you have tried and maybe suggest things to try.
BL0032 doesn't need a programmer port and so it is greayed out, when you click compile to chip it calls on the mLoader software packaged with Flowcode. For it to work you do need to have the USB drivers installed.
https://www.flowcode.co.uk/old_site/res ... rivers.zip
I've resized your panel components a bit for v10 and noticed that the connections for the GPS and the Keypad might not be correct.
Please can you go into the component properties and just check they look ok.
(36.55 KiB) Downloaded 723 times
