Hi Steve
on and off are somehow interchanged and also to set a led on/off is not correct.
And a few small wishes....
Would it also be possible to make the label font size adjustable?
and the off colour selectable?
So you can use it only as small array with three or two leds or even as a single indicator.
and I can use this on both panel
Demo for a record button with additional display whether recording is already in progress or has started or cannot be started
App Developer Led Array on/off reversed
- Has thanked: 246 times
- Been thanked: 258 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: App Developer Led Array on/off reversed
If you want customised fonts, etc, then it might be easier to just use primitive text and shapes for the indicators.
- Has thanked: 795 times
- Been thanked: 858 times
Hi.
Many thanks for the bug spot
Can you try with the attached component, please?
- LED_Array_2dgi.fcpx
- (8.98 KiB) Downloaded 441 times
Hi Martin
i have copied the component to
C:\Program Files (x86)\Flowcode v10\DefaultData\FlowcodeV10\Components
and it replaced the old one.
Started FC again, but no change in the component or function
- Snag_9b42c3.png (25.33 KiB) Viewed 5218 times
Hi Stefan.
That is the wrong location.
The components are copied from that location to the location below only when Flowcode is first installed
save the attached component from the post above in the above location
If Flowcode is already open, then you will need to reload your project for the new components to work.
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work.
Hi Martin
Perfect! Yes it's working nice.
Also test the Bargraph and WriteValue, and this works nice.
ols vs new
ols vs new
That's great!.
Thank you for the update.
I'm glad your project is now working as expected.
I have requested the updated component to be pushed on the update system ASAP.
Hi Martin
Thanks for the quick support.
But still a small problem as in the topic
https://flowcode.co.uk/forums/viewtopic.php?f=5&t=1864
Also this LED does not change correct.
I have used the traficligth at the moment
