Please can help me ?
I am test the potentiometro X9C103 but when copila to .hex say error.
Enrique
X9C103 (FIXED)
ELECTRONICA67
- Has thanked: 43 times
- Been thanked: 11 times
X9C103 (FIXED)
- X9S103V10.fcfx
- (16.68 KiB) Downloaded 703 times
- (view online)
- Has thanked: 795 times
- Been thanked: 858 times
Re: X9C103
Hello, many thanks for the report
The component fix will be pushed onto the update system ASAP.
If would you like to test before then, Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
If you run any component updates, then the components you added will be overwritten.
Can you let me know if it works for you, please?
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new components to work
- X9Cx0x_DigitalPot.fcpx
- (2.44 KiB) Downloaded 787 times
ELECTRONICA67
ELECTRONICA67
Re: X9C103
Sorry Martin, I responded to you several times. . .I didn't know that each question or answer on a topic had to be approved.
I expected to see the reply published when it was sent to the forum. I see that the rules have changed regarding past forums.
Enrique
Enrique
- Has thanked: 478 times
- Been thanked: 713 times
Re: X9C103
Hi Enrique
When a forum member first starts to post, the first few need to be approved before they are shown as a way to help reduce spam messages etc. When I logged in this morning I saw your posts and approved (I also deleted your duplicated ones).
Re: X9C103
Hi Enrique,
Your project file X9S103V10.fcfx did have an error for me, but now I can compile it to hex, after the component has been modified.
When you added the modified file did you get a prompt to override the original file and did you reload your project file before compiling?
If that is the case, can please attach your X9S103V10.c and X9S103V10.msg.txt files that are in the same directory as X9S103V10.fcfx
ELECTRONICA67
Re: X9C103
I can now compile the program to .hex, I am going to program the chip to test it, did you mention that there was an error in the flowchart ?
Enrique
Enrique
Re: X9C103
No, there was indeed a bug within the digital pot, which I have fixed.
I have not tested your project on hardware.
at least you can now compile which is great!
ELECTRONICA67
Re: X9C103
I restarted the test of the X9C103 Potentiometer, but I cannot increase or decrease the value of the resistance, the value remains fixed at 3.7 kohm, could you help me? I attach the flow chart.
Enrique
Enrique
- X9C103 with reading
- pot.jpg (58.49 KiB) Viewed 8961 times
- X9S103V10a.fcfx
- Flowchart
- (15.29 KiB) Downloaded 642 times
- (view online)
