ESP32 and servo controller/ ninja failed with exit code 1
dvcam99
Has thanked: 9 times
Been thanked: 14 times
Post by dvcam99 »
Hello together,
it seems to me that the servo controller component is not compatible with ESP32.
Compiling faild with the following message:
Attached the FC programm.
ESP32_Test3.fcfx
(11.49 KiB) Downloaded 961 times
BR
Dirk
Happy FC9, FC-8 and FC-6 professional user ;)
Has thanked: 647 times
Been thanked: 856 times
Re: ESP32 and servo controller/ ninja failed with exit code 1
Hi Dirk,
Thanks for letting us know. I'll investigate and see if I can get this resolved for you.
dvcam99
Post by dvcam99 »
very good!! Thanks in advance
Dirk
Hello Dirk,
Sorry for the delay the Servo motor component should now be supported by the ESP32 hardware. The only thing currently not supoorted is the AutoMove functions. The SetPosition and MoveToPosition macros should work correctly.
Please let me know if you have any problems.
dvcam99
Post by dvcam99 »
Many Thanks Ben,
I will check it out with in the next weeks
BR
Dirk
dvcam99
Post by dvcam99 »
Hello Ben,
just checked the attached FC9 file with serco controller. Unfortunately it give still a complier error.
ESP32_Test3_1.fcfx
(11.49 KiB) Downloaded 737 times
cc1.exe: some warnings being treated as errors
Running ninja in directory h:\esp32\esp32_test3_1\build
Executing "ninja all"...
Build Failed
Autoclose turned off
FINISHED
Many thanks for letting me know. I have replicated the problem you're having and have fixed it in the latest component. The problem was caused by only having a single servo channel enabled and it seems I had only tested with all 8 enabled. It should work as expected for you now.
I would also move the SetPosition call from inside the loop, to just before the loop in your program as updating the position in such a tight loop might cause you problems.
dvcam99
Post by dvcam99 »
many thanks for the super fast fix!! Works great. :D
Scope shot below:
Additional question!! Is there a way to edit the frame rate. Now it is fixed at 20ms (50Hz). Cool would be 15ms and 10ms (75Hz and 100Hz) too.
BR
Dirk
Hi Dirk,
Brilliant glad it's working for you the servo controller component is currently fixed to 50hz but the pwm component should allow you to easily do this.
dvcam99
Post by dvcam99 »
what do you mean with pwm component in order to change the frame rate fromm 50 to 100Hz
Should I use the PWM component instead of the servo controller component?? Is this your suggestion??
May is it possible to change the frame rate via a C-code??
BR
Dirk
