PWM no function after update
DirkB
Has thanked: 1 time
Been thanked: 4 times
Post by DirkB »
there has been an update to the PWM. After the update, the compiler returns an error. The PWM no longer works. My chip is the 16F1825. Everything worked fine until yesterday.
Here is the error message.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:2: error: (192) undefined identifier "MX_PWM_TRIS_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:27: error: (192) undefined identifier "MX_PWM_PIN_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:88:43: error: (192) undefined identifier "MX_PWM_PORT_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:340:1: error: (192) undefined identifier "MX_PWM_TRIS_11"
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_PWM.c:340:25: error: (192) undefined identifier "MX_PWM_PIN_11"
Dirk
Has thanked: 444 times
Been thanked: 669 times
Re: PWM no function after update
Post by chipfryer27 »
Can you attach your chart?
Also, after an update components sometimes "default" to initial pin values. It's worth checking that your pin assignments are still valid.
DirkB
Has thanked: 1 time
Post by DirkB »
of course, I always create a new project with this
component to rule out other errors. The same result.
DirkB
Has thanked: 1 time
Post by DirkB »
After the update to PWM V7 the PWM works. According to the data sheet,
the PIC18F14K22 has up to 4 PWM outputs. How can I set these?
Dirk
