Component VL53L0X download problem
Xbiotec
Has thanked: 37 times
Been thanked: 27 times
Flowcode v10 Component VL53L0X download problem
Post by Xbiotec »
hi,
When I'm trying to download the VL53L0X , I'm getting this below and the file is now downloaded
I tried with another component and it work well
thanks for a prompt reply
Seb
Has thanked: 300 times
Been thanked: 465 times
Re: Component VL53L0X download problem
Thanks for letting us know. This should get fixed soon.
In the meantime, you should be able to download the file by right-clicking and selecting "save link as...". This will currently only work if you visit the wiki in a browser rather than from within Flowcode itself.
Xbiotec
Post by Xbiotec »
Thx, it work's
Now I'm trying to use the XC16 PRO compiler from microchip like I'm using in FC9 but there is a error . "COFF format is not supported, please use ELF"
Target folder: C:\Users\seb\Documents\AAA Microchip
Source name:   C:\Users\seb\Documents\AAA Microchip\Flowcode1.fcfx
Title:
Description:
Device:        PIC16.24F.24FJ256GA705
Generated by:  Flowcode v10.0.4.33
Date:          Wednesday, November 15, 2023 16:56:47
Users:         1
Registered to: ---------
Licence key: ---------
https://www.flowcode.co.uk
Using <PICKit4 IPE Seb> user settings for compiler
Launching the compiler...
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat  "C:\Program Files (x86)\Flowcode\Compilers\xc16\v2.10\" "Flowcode1" "C:\Users\seb\Documents\AAA Microchip\" "24FJ256GA705"
C:\Users\seb\Documents\AAA Microchip>REM CRC: 54CD51B8F484283E91B3AD9DE6F4F50C418D34178E0D3D0BD2659E1DA9D69F58D3529BB9468CFC85641793EB31F94A5F16CBA8333F125C7188ED8742865A1BBCF23BFF3064C25A11BAFA61B701B8D0469A0D46BD3B6AACB92DE4D84759EBB5079CA9DA2D2BBCDAE2A4D1C56CD1580BF59733FFBBAA9F3C7B5EDF8CE67A1404D62B8878703E3665631EAF018A0B6018ACC8FF364DB19D83FB389861B26F27604A1F36255EB2E4245255911F067119BEF7D5F89C133B93261A29D848A5DAD12E38FF9E5CFBC45304482C3050DA273BE4EE70C46F1DEBB5CE90D191F7CB01DEE82F091CE1AC860B44C66CFC63B583D3C0065E5746CE888A1719
C:\Users\seb\Documents\AAA Microchip>REM REVISION: 1.0
C:\Users\seb\Documents\AAA Microchip>REM GUID: 7821ABE5-9E21-4744-81B7-3FF600B75DB7
C:\Users\seb\Documents\AAA Microchip>REM DATE: 08\08\2022
C:\Users\seb\Documents\AAA Microchip>REM DIR: FCD\PIC16\batchfiles\pic16_C30_comp.bat
C:\Users\seb\Documents\AAA Microchip>xc16-gcc -c -mcpu="24FJ256GA705" -omf=coff -funsigned-char -fno-short-double -Os -I"C:\Program Files (x86)\Flowcode\Compilers\xc16\v2.10\support\h" -I"C:\Program Files (x86)\Flowcode\Compilers\xc16\v2.10\" -std=gnu99 "Flowcode1".c -o "Flowcode1".o
Error returned from [xc16-gcc.exe]
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\PIC16\batchfiles\pic16_C30_comp.bat reported error code 0x1
Autoclose turned off
FINISHED
thx for your help
Seb
I think you need to use the updated batch files that I posted in the v9 thread:
viewtopic.php?p=12824#p12824
Xbiotec
Post by Xbiotec »
It' work's , sorry I didn't know that need to do the same in FC10
why you didn't update FC10 with these batch files ?
Seb
The work is planned I believe.
Xbiotec
Post by Xbiotec »
thx
Seb
Xbiotec
Post by Xbiotec »
hello
I was looking the code of the VL53L0X sensor.
Could you explain me why Macro "SetVcselPulsePeriod" is never used during initialize.
Range value is always 0
thx
Seb
As far as I can tell, this relates to a "long range / short range" option which is currently unimplemented in the component. If this is a feature you require then please let us know and we can look at implementing it.
Has thanked: 756 times
Been thanked: 819 times
Thanks Steve/Seb
I have not got a VL53L0X sensor to test with, but the long range / short range" option has now been implemented.
Can you please let me know how you get on with the change.
If you are happy with the change, the component modification will be pushed onto the update system next week.
Browse to this location using File Explorer, it's hidden by default so just paste the link into your address bar.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the components you added will be overwritten.
RangeTOF_VL53L0X.fcpx
(10.46 KiB) Downloaded 720 times
