Hi ,
This should be a very easy to do add
Uart Baud rate can be set programmatically but is missing the 600 Baud rate
is there any chance this could be added or even better make it custom baud rate.
I am using Flowcode V9
UART baud rate
- Has thanked: 54 times
- Been thanked: 26 times
- Has thanked: 358 times
- Been thanked: 565 times
Re: UART baud rate
V9 does have a custom option. In the UART properties, select Baud>Custom and you can set it to whatever. Do note that depending on your clock speed you may not be able to achieve every speed you may like.
I've not personally use the feature but it is there.
Hope this helps,
Hope this helps,
Re: UART baud rate
HI , Thanks for your reply ,
Yes it there , but i was referring changing baud when code is running
this feature is already there but it dose not have the 600 option
it begins from 1200
it begins from 1200
Re: UART baud rate
Sorry, missed that part.
I guess perhaps a C-Block could perhaps resolve?
Re: UART baud rate
Here is the code For changing the baud
Thanks to LeighM
MX_UART_NUMBER_1.Init.BaudRate = 600;
