UART baud rate
Alan_37
Has thanked: 57 times
Been thanked: 28 times
UART baud rate
Post by Alan_37 »
Hi ,
This should be a very easy to do add
Uart Baud rate can be set programmatically but is missing the 600 Baud rate
is there any chance this could be added or even better make it custom baud rate.
I am using Flowcode V9
Has thanked: 468 times
Been thanked: 697 times
Re: UART baud rate
V9 does have a custom option. In the UART properties, select Baud>Custom and you can set it to whatever. Do note that depending on your clock speed you may not be able to achieve every speed you may like.
I've not personally use the feature but it is there.
Hope this helps,
Alan_37
Re: UART baud rate
Post by Alan_37 »
HI , Thanks for your reply ,
Yes it there , but i was referring changing baud when code is running
this feature is already there but it dose not have the 600 option
it begins from 1200
Re: UART baud rate
Sorry, missed that part.
I guess perhaps a C-Block could perhaps resolve?
Alan_37
Re: UART baud rate
Post by Alan_37 »
Hi , Thanks for your reply
Yes that would be a good work around any idea
what to put in the C-Block to change the Baud
Working with stm32f401RC
Alan_37
Re: UART baud rate
Post by Alan_37 »
Here is the code For changing the baud
MX_UART_NUMBER_1.Init.BaudRate = 600;
Thanks to LeighM
