Hello, after updating flowcode version 8 to version 10 I am having problems with the components: DS18S20/DS18B20 and DHT22.
in the new version (10) I can't get either of these two sensors to work even after switching to different clock speeds.
So I come here to ask for help but I suspect there may be a bug in the new version of flowcode because I still have the old version (8) installed and the project works perfectly in this one.
problems with DS18S20/DS18B20 and DHT22 sensors
aderito
- Has thanked: 19 times
- Been thanked: 2 times
- Has thanked: 468 times
- Been thanked: 697 times
jgu1
- Has thanked: 871 times
- Been thanked: 212 times
Re: problems with DS18S20/DS18B20 and DHT22 sensors
sorry DHT22 for me also not working in FC10. I have to go back to FC8, then it work?
The att. project is a project open in FC10 from FC8.
Br Jorgen
Br Jorgen
- DHT22_LCD.fcfx
- (15.59 KiB) Downloaded 664 times
aderito
the first attachment is in version 8 and the second is in version 10 which does not work
- turbomacambuzio V10 DHT22 4620 lcd.fcfx
- (107.55 KiB) Downloaded 783 times
- turbomacambuzio V8 DHT22 4620 lcd.fcfx
- (87.14 KiB) Downloaded 652 times
aderito
the DS18S20/DS18B20 sensor I can't physically test because at the moment I don't have any available but using PROTEUS I can't get this sensor to work
aderito
Attached is a simple test created with fcv10 (does not work) and a simple test created with fcv8 that works perfectly.
Furthermore, I made "version 8" from the file created with "version 10"
- teste simples dht22 fcv8.fcfx
- (14.47 KiB) Downloaded 702 times
- teste simples dht22 fcv10.fcfx
- (17.92 KiB) Downloaded 677 times
In the Evil Lab today so I had a look around at what I have but unfortunately I don't have any DHT22 modules but I do have DHT11 modules, both use one-wire so.....
I created charts in v8 and v10.
The charts use an EB083 combo-board connected to a multiprogrammer with a PIC16F1939 running at 19.xxxMHZ.
The chart initialises the display then enters a loop.
In the loop we wait for a button to be pressed before sampling the sensor.
According to the component, SampleSensor returns 0 for success, 1 for No Comms and 2 for Checksum Error.
The chart branched depending on result. If 0 then it would go on to display humidity and temperature, if 1 it would inform of comms error and if 2 it would inform of checksum error.
In both charts the sensor returned 1, meaning No Comms.
Connecting a Logic Analyser set to decode 1-wire / DHT11/22 provided the following information
Zooming in we can see the sensor actually responded with correct readings
The same results were obtained using v10.
Changing the chart to display results if a "1" was returned (instead of a 0), the chart displayed the correct readings on hardware on the display.
It would seem that in both v8 and v10, Flowcode is either returning incorrect values, or there is a typo in description in that it should read 1 for success.
I'm not sure if this helps with your DHT22 issue or not.
Although still connected to a DHT11, I changed the component to a DHT22 just to see what happens. Whilst I wasn't expecting much really I was interested to see what was being transmitted. The DHT11/22 decoders didn't register anything but 1-wire caught Resets. Same with v8.
aderito
Hello, I noticed an error in the flowchart in the Switch icon......
I forgot to declare the variable in this operation so never exit this loop....
my distraction...
Attached I will post the correct flowcharts
my distraction...
- (18.71 KiB) Downloaded 759 times
- teste simples dht11 fcv10.fcfx
- (18.71 KiB) Downloaded 681 times
aderito
hello,
I took some screenshots during the simulation with Proteus and it can be seen that in the "dht22 fc10" capture the times are somewhat different from the other captures.
I emphasize that the dht11 component works well in both fc8 and fc10
- captura dht22 fc8.png (401.81 KiB) Viewed 10297 times
- captura dht11 fc10.png (399.7 KiB) Viewed 10297 times
- captura dht11 fc8.png (399.43 KiB) Viewed 10297 times
