ST7789 Font problem [SOLVED]
Sasi
Has thanked: 43 times
Been thanked: 15 times
Flowcode v10 ST7789 Font problem [SOLVED]
Post by Sasi »
I am using ST7789 display with PIC24FJ1024GB610 MCU.
When I compile the attached project, I get an error message if I use the "Verdana Number 24" font.
Sasi
PIC24FJ1024GB610 ST7789 Font_test.fcfx
(16.05 KiB) Downloaded 734 times
Has thanked: 311 times
Been thanked: 479 times
Re: ST7789 Font problem
Thanks. It looks like there is a typo in the font definition for that particular font. We will fix this hopefully today.
Has thanked: 795 times
Been thanked: 858 times
I believe I have resolved the issue.
If you would like to try the component before the update is pushed.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
If you run any component updates, then the component you added will be overwritten.
gLCD_Font.fcpx
(21.26 KiB) Downloaded 545 times
Sasi
Post by Sasi »
Thank you very much. It works!
Re: ST7789 Font problem [SOLVED]
That's great!
Thanks for letting us know.
