I am using ST7789 display with PIC24FJ1024GB610 MCU.
When I compile the attached project, I get an error message if I use the "Verdana Number 24" font.
Sasi
ST7789 Font problem [SOLVED]
Sasi
- Has thanked: 43 times
- Been thanked: 15 times
- Has thanked: 311 times
- Been thanked: 479 times
Re: ST7789 Font problem
Thanks. It looks like there is a typo in the font definition for that particular font. We will fix this hopefully today.
- Has thanked: 795 times
- Been thanked: 858 times
I believe I have resolved the issue.
If you would like to try the component before the update is pushed.
Browse to this location using file explorer, it's hidden by default so just paste the link into your address bar.
If you run any component updates, then the component you added will be overwritten.
C:\ProgramData\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- gLCD_Font.fcpx
- (21.26 KiB) Downloaded 544 times
