ATTINY4313 UART compiling error
ChrisT66
Been thanked: 1 time
Post by ChrisT66 »
Hello, the UART cannot be initialized. There are several error messages when compiling.
Please check, thank you!
Regards Chris
Has thanked: 295 times
Been thanked: 459 times
Re: ATTINY4313 UART compiling error
Please attach a project showing this and we'll have a look.
ChrisT66
Post by ChrisT66 »
I have created a project with the 4313. The error message appears.
And a project with the 2313 (same controller with less memory). Here it works as it should.
Thank you.
4313UART.fcfx
Does not work
(8.17 KiB) Downloaded 580 times
2313UART.fcfx
Works
(8.16 KiB) Downloaded 474 times
ChrisT66
Post by ChrisT66 »
Have I already looked at this error? Greetings Christian
Hi Christian,
Thanks for the reminder. I can confirm the problem and someone is looking into the issue. Unfortunately, there is not a simple fix, so I cannot say when it will be resolved. I will ask for an update and let you know.
