Hello, the UART cannot be initialized. There are several error messages when compiling.
Please check, thank you!
Regards Chris
ATTINY4313 UART compiling error
ChrisT66
- Been thanked: 1 time
- Has thanked: 311 times
- Been thanked: 479 times
Re: ATTINY4313 UART compiling error
I have created a project with the 4313. The error message appears.
And a project with the 2313 (same controller with less memory). Here it works as it should.
Thank you.
Thank you.
- 4313UART.fcfx
- Does not work
- (8.17 KiB) Downloaded 601 times
- (view online)
- 2313UART.fcfx
- Works
- (8.16 KiB) Downloaded 491 times
- (view online)
Hi Christian,
Thanks for the reminder. I can confirm the problem and someone is looking into the issue. Unfortunately, there is not a simple fix, so I cannot say when it will be resolved. I will ask for an update and let you know.
