I am new with Flowcode 10 (free version). I have experience with Flowcode 6 but this was long time ago.....
So, when I try to compile to target I have this error:
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/esp-project.c.obj
what I have found till now is if I have even just one component macro I receive this error.
Maybe I am doing something wrong or I should install something additional, or maybe component macros are not for the free version?
I appreciate any help.
thanks
Python 3.7.3
git version 2.21.0.windows.1
ESP toolchain found at "C:\Users\User\Desktop\esp-idf\"
esp compile error
noovas
Re: esp compile error
Hello, medelec35
project name is: Flowcode2.fcfx
attached file is the .txt file
- Flowcode2.msg.txt
- (175.23 KiB) Downloaded 593 times
inside there is just one component macro (in my case PWM enable)
- Flowcode2.fcfx
- (8.56 KiB) Downloaded 720 times
- Has thanked: 724 times
- Been thanked: 783 times
After selecting PWM:0 Timer:0 Pin:A from the PWM Timer properties, your project compiled for me.
Can you give that a try and attach the latest .msg.txt if still not compiling for you.
At least now compiling will be a lot quicker as it won't be the first time of compiling.
That means all the components are now free and there are no code size restrictions, unlike all the other versions of Flowcode.
Flowcode 10 is free for makers and hobbyists.
I have tried many times with different projects, different versions of Python. Few times I reinstall and the ESP toolchain, but without success.
If the project contains output, loops and delays it compiles without problem (making a led flash is not a problem and it uploads ).
here is latest .txt report....
- Flowcode2.msg.txt
- (30.56 KiB) Downloaded 569 times
- Has thanked: 616 times
- Been thanked: 815 times
This is the error you're getting.
It looks like you need to go to Help -> Library Updates and get the latest files. Hopefully that should allow you to compile.C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_PWM.c:48:8: error: no macro name given in #define directive
48 | #define
Hello BenR and thank you for the help!!!
Actually thank you very much, it is working now!!
