Hello Matrix team,
how can I managed it, to compile a Flowcode C-File in MPLAB? I got a lot of errors. Info: For future the C90 library is discontinued by Microchip.
Errors:
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make -f nbproject/Makefile-default.mk dist/default/production/Test.X.production.hex
make[2]: Entering directory 'C:/Downloads/Test.X'
"C:\Program Files\Microchip\xc8\v2.46\bin\xc8-cc.exe" -mcpu=12F617 -c -mdfp="C:/Program Files/Microchip/MPLABX/v6.20/packs/Microchip/PIC10-12Fxxx_DFP/1.7.178/xc8" -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default -msummary=-psect,-class,+mem,-hex,-file -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mno-default-config-bits -std=c90 -gdwarf-3 -mstack=compiled:auto:auto -o build/default/production/_ext/1472/PIC12F617_V10.p1 ../PIC12F617_V10.c
advisory: (2099) legacy C90 library is deprecated and will be discontinued in a future release; consult the release notes for more details
advisory: (2095) legacy HI-TECH support is deprecated and will be discontinued in a future release; consult the release notes for more details
../PIC12F617_V10.c:32:45: warning: (1388) configuration setting/register of "CONFIG" with 0x3F94 will be truncated by 0xFFF
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:199:50: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:205:27: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:206:50: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:212:33: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:218:23: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:219:33: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:500:19: warning: (373) implicit signed to unsigned conversion
Jorg
C-File from Version 10 to MPLAB
Jorg_Guldner
- Been thanked: 4 times
- Has thanked: 292 times
- Been thanked: 458 times
Re: C-File from Version 10 to MPLAB
I can see only warnings in that excerpt and no errors. Can you post the full file?
Jorg_Guldner
Hello!
Here is the old file.....
Jorg
Jorg
- PIC12F617_V10.fcfx
- (35.57 KiB) Downloaded 537 times
Sorry. I mean the file (or a complete output listing) with the errors that was produced when you ran the C-code file through MPLAB.
Jorg_Guldner
Hello!
Here is the complete message from MPLAB.
Jorg
Jorg
- PIC12F617_Compile meassage MPLAB.txt
- (20.49 KiB) Downloaded 587 times
Thanks. Looking at that file, there are no errors being reported and the build is reported as being successful. So your project should work ok.
The warnings being reported can probably be ignored.
Jorg_Guldner
Hello!
Thanks for the info.
"Succsessfully compiled" means, that all is OK without errors?
Jorg
Jorg
