C-File from Version 10 to MPLAB
Jorg_Guldner
Been thanked: 4 times
Post by Jorg_Guldner »
Hello Matrix team,
how can I managed it, to compile a Flowcode C-File in MPLAB? I got a lot of errors. Info: For future the C90 library is discontinued by Microchip.
Errors:
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make -f nbproject/Makefile-default.mk dist/default/production/Test.X.production.hex
make[2]: Entering directory 'C:/Downloads/Test.X'
"C:\Program Files\Microchip\xc8\v2.46\bin\xc8-cc.exe" -mcpu=12F617 -c -mdfp="C:/Program Files/Microchip/MPLABX/v6.20/packs/Microchip/PIC10-12Fxxx_DFP/1.7.178/xc8" -fno-short-double -fno-short-float -O0 -fasmfile -maddrqual=ignore -xassembler-with-cpp -mwarn=-3 -Wa,-a -DXPRJ_default=default -msummary=-psect,-class,+mem,-hex,-file -ginhx32 -Wl,--data-init -mno-keep-startup -mno-osccal -mno-resetbits -mno-save-resetbits -mno-download -mno-stackcall -mno-default-config-bits -std=c90 -gdwarf-3 -mstack=compiled:auto:auto -o build/default/production/_ext/1472/PIC12F617_V10.p1 ../PIC12F617_V10.c
advisory: (2099) legacy C90 library is deprecated and will be discontinued in a future release; consult the release notes for more details
advisory: (2095) legacy HI-TECH support is deprecated and will be discontinued in a future release; consult the release notes for more details
../PIC12F617_V10.c:32:45: warning: (1388) configuration setting/register of "CONFIG" with 0x3F94 will be truncated by 0xFFF
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:199:50: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:205:27: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:206:50: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:212:33: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:218:23: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_IO.c:219:33: warning: (373) implicit signed to unsigned conversion
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\PIC\PIC_CAL_String.c:500:19: warning: (373) implicit signed to unsigned conversion
Jorg
Has thanked: 268 times
Been thanked: 432 times
Re: C-File from Version 10 to MPLAB
I can see only warnings in that excerpt and no errors. Can you post the full file?
Jorg_Guldner
Hello!
Here is the old file.....
Jorg
PIC12F617_V10.fcfx
(35.57 KiB) Downloaded 518 times
Sorry. I mean the file (or a complete output listing) with the errors that was produced when you ran the C-code file through MPLAB.
Jorg_Guldner
Hello!
Here is the complete message from MPLAB.
Jorg
PIC12F617_Compile meassage MPLAB.txt
(20.49 KiB) Downloaded 566 times
Thanks. Looking at that file, there are no errors being reported and the build is reported as being successful. So your project should work ok.
The warnings being reported can probably be ignored.
Jorg_Guldner
Hello!
Thanks for the info.
"Succsessfully compiled" means, that all is OK without errors?
Jorg
WingNut
Has thanked: 50 times
Been thanked: 37 times
Post by WingNut »
It usually means it will work but you have a lot of 'warnings' which might produce unexpected results in hardware so you should try to resolve these
