Protocol j1587
Has thanked: 177 times
Been thanked: 1016 times
Re: Protocol j1587
Post by mnfisher »
You can set a character in a string to 128.as above. Each character is a byte. You can set values using a number as shown or a character (in single quotes) or set the whole string.
Re: Protocol j1587
Post by mnfisher »
Just done a quick test
I did PutArray(.test, 10)
LookForValue(.seek, 1, true, true)
Where test = {x,x,x,128,129...) where x is any value
and seek[0] = 128
LookForValue just returns 1 if the search value is found. (would the index (or -1) be better?) Then GetByte returns the 'following' data
So in this case - the GetByte returns 129
If you are using an interrupt to load the data - you could use WaitForValue as an alternative..
cb.fcfx
(9.38 KiB) Downloaded 717 times
RGV250
Has thanked: 46 times
Been thanked: 48 times
Re: Protocol j1587
Post by RGV250 »
When you say it works on the bench are you using live data from the tractor or some simulator? If it is live data then are you using a bench PSU and when on the tractor using the tractor supply. Does it work OK with the engine not running and then give problems when it is running?
Bob
bios33
Has thanked: 12 times
Re: Protocol j1587
Post by bios33 »
Thank you very much "minfisher" for the example, it helped me understand searching for data in the buffer.
Now there is a new problem: the bytes are repeated on the screen, although I display them in turn from "Mid_array[0] to Mid_attay[3]. What could be the problem?
Regards Joni!
V1.6.fcfx
(21 KiB) Downloaded 778 times
bios33
Re: Protocol j1587
Post by bios33 »
RGV250 wrote:
Wed Mar 13, 2024 12:28 pm
Bob
Greetings! Everything is fine with the food, there are no problems, that’s for sure. The problem is that the device does not work correctly when other control units are on the bus. For example: in a certain line checksum =102 and at the same time there is PID 102 - turbo pressure and mixing the turbine readings skips unnecessary data, and so on with almost all indicators. Something like this
Re: Protocol j1587
Post by mnfisher »
I think the issue is - your code continually searches for 128 - and as soon as it is found - attempts to read 4 bytes from 'after' the 128.
These may not have been received yet...
So - one solution is wait for 128 to be found then wait until caunt_rx >= 4 and then display the values.
Re: Protocol j1587
Post by mnfisher »
I tried this - I've used a timer interrupt to add data if running as a simulation.
V1.7.fcfx
(23.77 KiB) Downloaded 673 times
bios33
Re: Protocol j1587
Post by bios33 »
Hi all!
I tried V1.7 but the repetition is still there, I changed the delay but alas to no avail, everything is perfect in the simulator.
I’ll transfer it to the mega2560 in a minute and try, maybe there’s a problem with the controller.
Re: Protocol j1587
Post by mnfisher »
Odd, how about waiting until the value changes from 128 - it sounds as though only the start byte is being received correctly. Can you just display (or send to uart) all the data received?
bios33
Re: Protocol j1587
Post by bios33 »
Here are the screenshots
The controller receives the same data as the FC
Out STM to LCD.png (53.07 KiB) Viewed 7473 times
J1587 in to FC.png (96.52 KiB) Viewed 7473 times
