IPS display ST7735 80 X 160
solozerouno
- Has thanked: 2 times
- Been thanked: 2 times
You can add a new display with these features: IPS color 80 * 160 display SPI Interface Control chip: ST7735
- Has thanked: 607 times
- Been thanked: 803 times
Re: IPS display ST7735 80 X 160
I've bought one for you so I can develop a component. Should hopefully arrive later this week.
https://www.ebay.co.uk/itm/386858565278
There's now a tested working component available for you now if you do a full database library update.
jgu1
- Has thanked: 829 times
- Been thanked: 204 times
Hi Ben!
I have order a couble of these display, exactly same as you bougth. I see that it (from seller) is possible to use3,3v and 5v.
When you test do you use 5V or 3,3V or resistor devider, please.
Thank´s in advance
Br jorgen
Thank´s in advance
Br jorgen
- St7735S_Test.fcfx
- (14.42 KiB) Downloaded 633 times
Hi Jorgen
I used an arduino at 5v and it worked fine for me.
jgu1
hi again!
Working
really brigth and clear display, wow. But I have to set the Pixelwith to 130 and the Pixelhigh to 162 otherwice I see line in the rigth side and in the buttom, when using these setting it is full screen, is that normal, never need that before?
But working perfect with these setting and FC, and not a problem to align.
And is it not possible to set the orientation on ST7735 like all the other display
jorgen
Working
jorgen
- St7735S_Test.fcfx
- (14.99 KiB) Downloaded 558 times
