IPS display ST7735 80 X 160
solozerouno
Has thanked: 2 times
Been thanked: 2 times
Flowcode v10 IPS display ST7735 80 X 160
Post by solozerouno »
You can add a new display with these features: IPS color 80 * 160 display SPI Interface Control chip: ST7735
Has thanked: 647 times
Been thanked: 856 times
Re: IPS display ST7735 80 X 160
I've bought one for you so I can develop a component. Should hopefully arrive later this week.
https://www.ebay.co.uk/itm/386858565278
There's now a tested working component available for you now if you do a full database library update.
Has thanked: 910 times
Been thanked: 220 times
Flowcode v10 Re: IPS display ST7735 80 X 160
Post by jgu1 »
Hi Ben!
I have order a couble of these display, exactly same as you bougth. I see that it (from seller) is possible to use3,3v and 5v.
When you test do you use 5V or 3,3V or resistor devider, please.
Thank´s in advance
Br jorgen
St7735S_Test.fcfx
(14.42 KiB) Downloaded 666 times
Hi Jorgen
I used an arduino at 5v and it worked fine for me.
Post by jgu1 »
Thank you Ben :D
Jorgen
Post by jgu1 »
hi again!
Working :D really brigth and clear display, wow. But I have to set the Pixelwith to 130 and the Pixelhigh to 162 otherwice I see line in the rigth side and in the buttom, when using these setting it is full screen, is that normal, never need that before? ;)
But working perfect with these setting and FC, and not a problem to align.
And is it not possible to set the orientation on ST7735 like all the other display :idea:
jorgen
St7735S_Test.fcfx
(14.99 KiB) Downloaded 587 times
