Posts: 1300 http://meble-kuchenne.info.pl
Has thanked: 246 times
Been thanked: 258 times
Post
by stefan.erni » Thu Mar 21, 2024 9:16 am
I use a simple Led on/off program
ESP32-S3_DeviceKitC is ok
ESP32-S3_Mini is not compiling.
A fatal error occurred: This chip is ESP32-S3 not ESP32-S2. Wrong --chip argument?
CMake Error at run_serial_tool.cmake:56 (message):
Posts: 2334 Joined: Mon Dec 07, 2020 10:06 am
Has thanked: 647 times
Been thanked: 856 times
Post
by BenR » Thu Mar 21, 2024 9:32 am
Many thanks for letting us know, should be resolved for you now via the library updates.
Posts: 1300 Joined: Wed Dec 02, 2020 10:53 am
Post
by stefan.erni » Thu Mar 21, 2024 11:15 am
Perfect it's compiling with Led on/off !
So i connented the display and it's compiling only if I use the SPI in software mode.
The display works fine in software mode.
Maybe you can take a look at why it doesn't work with the hardware SPI
Softwaremode ok:
Program:
Post
by BenR » Thu Mar 21, 2024 11:42 am
It's compiling fine for me in hardware mode. Can you post the .msg.txt file from a failed compilation and I'll have a look.
Post
by BenR » Thu Mar 21, 2024 2:06 pm
Hello Stefan,
Could simply be your IDF version. You're using 4.4.6 and I'm on 5.1.
You could try adding this line to the defines section of the supplementary code in the project options.
but there may be other problems too.
There is also a way to upgrade your IDF version to 5.1 without having to reinstall, it works ok for me but others have had mixed results.
See here for details.
viewtopic.php?p=9222#p9222
Post
by stefan.erni » Thu Mar 21, 2024 4:24 pm
I did both.
I get my notebook with ESP-IDS 5.1 and it's not compiling but in softwaremode it's ok
and i add the code and it did not compile
Post
by BenR » Fri Mar 22, 2024 10:29 am
This is the error you're getting.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_SPI.c:156:52: error: 'HSPI_HOST' undeclared (first use in this function); did you mean 'SPI3_HOST'?
Did you add the code snippet to the top window of the Supplementary Code? Could you please attach your latest .fcfx project file and .c file.
Post
by stefan.erni » Fri Mar 22, 2024 11:18 am
here are the desired files.For this I used my computer with the ESP-IDF 4.4.6
But it was the same yesterday on the notebook with ESP-IDF 5.1
insert the code here?
Post
by stefan.erni » Tue Apr 09, 2024 3:33 pm
SPI hardware is not working.
I have tried with other components and with the SPI component and add #define ....
Just in software mode it is possible to compile.
