ESP32-S3_Mini not compiling
Has thanked: 246 times
Been thanked: 258 times
I use a simple Led on/off program
ESP32-S3_DeviceKitC is ok
ESP32-S3_Mini is not compiling.
A fatal error occurred: This chip is ESP32-S3 not ESP32-S2. Wrong --chip argument?
CMake Error at run_serial_tool.cmake:56 (message):
Has thanked: 647 times
Been thanked: 856 times
Re: ESP32-S3_Mini not compiling
Many thanks for letting us know, should be resolved for you now via the library updates.
Perfect it's compiling with Led on/off !
So i connented the display and it's compiling only if I use the SPI in software mode.
The display works fine in software mode.
Maybe you can take a look at why it doesn't work with the hardware SPI
Softwaremode ok:
Program:
S3_24_1.fcfx
(16.22 KiB) Downloaded 786 times
It's compiling fine for me in hardware mode. Can you post the .msg.txt file from a failed compilation and I'll have a look.
Yes here...
S3_24_1.msg - Copy.txt
(27.76 KiB) Downloaded 913 times
Hello Stefan,
Could simply be your IDF version. You're using 4.4.6 and I'm on 5.1.
You could try adding this line to the defines section of the supplementary code in the project options.
#define HSPI_HOST SPI3_HOST
but there may be other problems too.
There is also a way to upgrade your IDF version to 5.1 without having to reinstall, it works ok for me but others have had mixed results.
See here for details.
viewtopic.php?p=9222#p9222
I did both.
I get my notebook with ESP-IDS 5.1 and it's not compiling but in softwaremode it's ok
and i add the code and it did not compile
(30.16 KiB) Downloaded 865 times
This is the error you're getting.
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_SPI.c:156:52: error: 'HSPI_HOST' undeclared (first use in this function); did you mean 'SPI3_HOST'?
Did you add the code snippet to the top window of the Supplementary Code? Could you please attach your latest .fcfx project file and .c file.
here are the desired files.For this I used my computer with the ESP-IDF 4.4.6
But it was the same yesterday on the notebook with ESP-IDF 5.1
C3_24_1.fcfx
(6.94 KiB) Downloaded 749 times
C3_24_1.c
(1.68 KiB) Downloaded 946 times
insert the code here?
SPI hardware is not working.
I have tried with other components and with the SPI component and add #define ....
Just in software mode it is possible to compile.
