GPS
ELECTRONICA67
Has thanked: 31 times
Been thanked: 9 times
Flowcode v10 GPS
Post by ELECTRONICA67 »
Hello, I would appreciate some help,
I am migrating programs that I have made from previous versions of flowcode, V5, V6, V7 to the new version 10, at this moment I am with a program that uses the GPS component, to read Latitude and Longitude; but I can't read the location, it sends me 0.000000 and 0.000000, I use the example and another program that I believe simplifies the example using new options offered by Flowcode 10.
I send the flowcharts of 2 examples that do not work for me.
Enrique
UBICACION.fcfx
(16.31 KiB) Downloaded 639 times
TEST1939v10.fcfx
(15.52 KiB) Downloaded 574 times
ELECTRONICA67
Flowcode v10 Re: GPS
imagen
ELECTRONICA67
After 3 hours one of the programs (TEST1939v10) could be connected, but with readings that constantly varied. . .
ELECTRONICA67
Yesterday, the circuit was connected and in 8 hours no satellite was connected.
ELECTRONICA67
The longitude is correct, the Latitude varies too much
ELECTRONICA67
Re: GPS
I was using a socket for the GPS, I'm going to solder it directly to the PCB
ELECTRONICA67
Re: GPS
The latitude continues to vary a lot, the longitude remains constant and correct, on average for every 10 readings, it sends a correct latitude
ELECTRONICA67
I think maybe the GPS component needs to be fixed.
I have installed and designed (Flowcode) a GPS in my car for more than 9 years and it works correctly and gives me the exact location of where it is.
kersing
Has thanked: 81 times
Been thanked: 65 times
Re: GPS
Post by kersing »
Have you tested this hardware setup with the same software you used before?
ELECTRONICA67
Re: GPS
Yes; I'm going to change the GPS to verify that it is not the fault.
