Can you provide a component for the "Matrix Keypad Module V3.0" keyboard?
niedian
Has thanked: 3 times
Been thanked: 5 times
Flowcode v10 Can you provide a component for the "Matrix Keypad Module V3.0" keyboard?
Post by niedian »
I see the information link: (https://emakefun-arduino-library.github ... index.html)
niedian
Re: Can you provide a component for the "Matrix Keypad Module V3.0" keyboard?
Post by niedian »
Developed using the BS8116A-3 touch chip.
niedian
Post by niedian »
Touch matrix keyboard module link: https://pan.baidu.com/s/1aIHu_GYLSGBms0jNiFKSGg
Extraction code: whi1
Has thanked: 647 times
Been thanked: 856 times
Looks like this board and the chip is potentially pretty niche and so writing a component around it at the moment probably isn't that appealing. I say this mainly because I can't find them for sale anywhere.
However the I2C interface looks simple enough so I've put together an example for you that should work.
BS81xA.fcfx
(15.92 KiB) Downloaded 723 times
If this board or chip becomes a bit more mainstream then yes certainly worth writing a component for it.
Please note I haven't looked at the library you suggested and so my demonstration threshold values etc may be incorrect.
Based on the datasheet I found here.
https://www.holtek.com/webapi/116711/BS81xA-xv160.pdf
niedian
Post by niedian »
Thank you very much, I'll give it a try.
