Can you provide a component for the "Matrix Keypad Module V3.0" keyboard?
I see the information link: (https://emakefun-arduino-library.github ... index.html)
niedian
- Has thanked: 3 times
- Been thanked: 5 times
- Snipaste_2024-03-24_11-49-42.png (301.81 KiB) Viewed 5608 times
Re: Can you provide a component for the "Matrix Keypad Module V3.0" keyboard?
Touch matrix keyboard module link: https://pan.baidu.com/s/1aIHu_GYLSGBms0jNiFKSGg
Extraction code: whi1
- Has thanked: 647 times
- Been thanked: 856 times
Looks like this board and the chip is potentially pretty niche and so writing a component around it at the moment probably isn't that appealing. I say this mainly because I can't find them for sale anywhere.
However the I2C interface looks simple enough so I've put together an example for you that should work.
If this board or chip becomes a bit more mainstream then yes certainly worth writing a component for it.
Please note I haven't looked at the library you suggested and so my demonstration threshold values etc may be incorrect.
Based on the datasheet I found here.
https://www.holtek.com/webapi/116711/BS81xA-xv160.pdf
