License Activation
pmaud
License Activation
Post by pmaud »
I am new to Flowcode and having followed an online tutorial I :?: have built a very simple test project.
When I try to compile it to the target Arduino Nano I get a message stating "You do not have a valid license to perform this action". I have tried all the functions I can find in the HELP tab under licensing, but cannot see a solution.
Any help would be appreciated
Has thanked: 442 times
Been thanked: 661 times
Re: License Activation
Post by chipfryer27 »
What "nano" are you trying to use?
Has thanked: 724 times
Been thanked: 783 times
If you have not purchased any chip packs, then the only hardware that will work is listed here
pmaud
Post by pmaud »
It was Nano 328 115200, but I have changed it to Nano 328.
It now compiles, but with the following error.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\AVR\batchfiles\avrc_arduinoA.bat reported error code 0x1
I'm not sure what this means though
Can you select Full Editor & Preview, below the reply window, Select attachments and upload the .fcfx, .msg.txt and .c files within the project folder.
Without seeing those files we can only guess.
Do you have the nano drivers installed and selected the correct comport (bottom righthand side) from within Build > Project Options...
pmaud
Post by pmaud »
Hello Martin,
I do not understand the first question you asked re Full Editor etc. I cannot see this on the forum page
Second question.Nano responds to Arduino IDE upload, so Drivers and Port should be ok, I think
kersing
Has thanked: 81 times
Been thanked: 65 times
Post by kersing »
Full editor and preview refers to the marked button in the picture below.
Once you select it you can use “Attachments” below the text box to add the requested files.
pmaud
Post by pmaud »
files attached
TestLED1.h
(1.82 KiB) Downloaded 592 times
TestLED1.fcfx
(9.17 KiB) Downloaded 544 times
TestLED1.c
(3.66 KiB) Downloaded 563 times
Sorry to be brief.
Your chart compiles OK for me. Did you download the toolchain / drivers from the Flowcode page?
https://www.flowcode.co.uk/download/
You are missing the .msg.txt file
That would be a big help for us if you had downloaded the AVR/Arduino toolchaain
