App Developer XY-Chart add few more series
Has thanked: 245 times
Been thanked: 256 times
Would it be possible to have a few more series for the XY-Chart component? 10 instead of 8 would be good, 16 would be great. With 16 series, the chart fits to the DSP Multiplexer component.
Has thanked: 300 times
Been thanked: 465 times
Re: App Developer XY-Chart add few more series
It could be done, but at the moment this would be quite difficult. I will have a look and see if there is any way to make this easier.
Hi Steve
What about the extension from the chart Series to 10 or 16?
Flowcode v10 Re: App Developer XY-Chart add few more series
Hi Stefan,
If you need more traces on a chart, then you can use 2 charts as in the attached example.
The two charts are in the same location and one of them has a transparent background, so it will look like there is only one chart. You can use this trick to have as many traces on chart as you want.
ten traces.png (352.08 KiB) Viewed 8124 times
ten traces example.fcsx
(29.38 KiB) Downloaded 724 times
Hi Steve
Yes thats working fine.
Just one small question.
can i set parameters with a build in function (command).
like this example :
I'm not sure. There are dedicated functions to reposition components. What are you trying to achieve?
with a switch the user can choose whether he wants the chart overlapping or separate. to do this i have to change the y position of the chart.
can still ask something unimportant.
Why can I only choose 5 series and not 8?
stefan.erni wrote:
Thu May 30, 2024 4:59 pm
We use a 3rd-party graphing tool within Flowcode for this and that is limited to 5 different colours for the traces. So trace 5 must be the same colour as trace 1, etc.
This can be overcome using that overlapping chart trick. BTW, you could have more than 2 overlapping if you needed. But lots of traces on the same chart can be difficult to view for the user.
I will answer your other question shortly...
A lot of the old object move function calls are not yet implemented for the 2d panel, so I would suggest making objects visible or invisible instead of actually moving them on the panel programmatically. This allows you to be more precise with their positions too. See the attached for an example.
ten traces example 02.fcsx
(39.74 KiB) Downloaded 652 times
