error when compiling with fc 10
aderito
Has thanked: 19 times
Been thanked: 2 times
Re: error when compiling with fc 10
Post by aderito »
I modified the file name a little and also the size of the name, I compiled it but without success.... it still gives the same error....
Attached are all the files produced during compilation.
I hope I can get some help here, I'm desperate.... :mrgreen:
6722.rar
(480.21 KiB) Downloaded 385 times
Has thanked: 311 times
Been thanked: 479 times
We are looking into this. A couple of my colleagues are seeing what you are seeing. But my PC seems to be compiling it ok. The C code being produced by Flowcode is the same on the PCs, so it's not an issue with Flowcode itself.
It could be the exact version of XC8 that is being used (I am using v2.45), but my colleagues have tried with v2.10 and v2.46 and it fails when using those versions. So I think it's not the XC8 version.
We are continuing to investigate.
aderito
Post by aderito »
OK thank you.
By the way, how can I see the version of my xc8?
thanks !
aderito
Post by aderito »
am I correct?
my version is 2.46?
I have mplab IPE installed but I'm only using the programmer in conjunction with pickit3, however this application comes from some time ago and I'm not sure if at the time xc8 was installed from mplab or from flowcode.. ... :roll:
versao xc8.png (304.66 KiB) Viewed 8188 times
You are using v2.10 (it's on the first line of the .s file that is produced).
Another difference between my Flowcode output and yours is I am using separate .c and .h files. You could try this setting (in Global Options) and see if this works for you.
aderito
Post by aderito »
Unfortunately it looks like I won't be able to do that..... :|
opcoes globais.png (319.45 KiB) Viewed 8172 times
Ok, no problem. I don't think that would solve it anyway.
I did find a similar issue to yours when I searched the internet on our pre-v9 forums:
https://www.flowcode.co.uk/mmforums/vie ... 26#p104326
aderito
Post by aderito »
It's always the most insignificant things that can turn into a nightmare..... :evil: :evil: :evil:
Following your instructions, I unchecked the "add icons comments to code" box and to my surprise it is already compiling..... :P :P
I hope there are no more surprises in the future and I thank you in advance for all the effort you made. :D :D
Perhaps it will also serve as an example for other people with a similar problem. :idea: :idea:
Great news. Thanks for sharing.
