Just a quickie to suggest a convenient I3C component, with each dashboard instance defined by the third line used for targeted communication.
With I2C backwards compatibility, it's certainly an easy workaround by separately activating the third line for affected devices, though I do see emerging devices that feature I3C.
I anticipate a relatively simple modification to the I2C component to directly support I3C, permitting multiple dashboard instances that share SDA/SCL but labelled according to target devices, with options box for the third line in the parameters field that effectively defines each instance, and added features in the dashboard icon tree that directly supports other aspects unique to I3C (e.g. set slave address, get BCR, get DCR, etc..etc..).
As I say... not essential with custom macros, but just a thought
Many thanks,
Brendan
