I3C Component
Brendan
Has thanked: 64 times
Been thanked: 17 times
I3C Component
Post by Brendan »
Hi team.
Just a quickie to suggest a convenient I3C component, with each dashboard instance defined by the third line used for targeted communication.
With I2C backwards compatibility, it's certainly an easy workaround by separately activating the third line for affected devices, though I do see emerging devices that feature I3C.
I anticipate a relatively simple modification to the I2C component to directly support I3C, permitting multiple dashboard instances that share SDA/SCL but labelled according to target devices, with options box for the third line in the parameters field that effectively defines each instance, and added features in the dashboard icon tree that directly supports other aspects unique to I3C (e.g. set slave address, get BCR, get DCR, etc..etc..).
As I say... not essential with custom macros, but just a thought :)
Many thanks,
Brendan
Has thanked: 634 times
Been thanked: 842 times
Re: I3C Component
Hi Brendan,
I3C sounds interesting, I hadn't come across it before. Do you have a device in mind that requires it?
Not sure what you mean by this.
Should be easy enough to implement, looks like we would have to have a new property that set if the bus was I2C or I3C e.g. open collector or fully driven and in fully driven mode allow faster speeds etc.
Has thanked: 245 times
Been thanked: 257 times
Re: I3C Component
Hi Ben, Hi Brendan
For my next project I like to use a LSM6DSV in a faster mode like I3C or SPI
LSM6DSV has a i3c and a flowcode component with i2c is already available
I could do a test at any time with I3C or spi
I would use an ESP32 but if there is a faster processor I could also change.
Maybe there is a better one?
https://www.st.com/resource/en/applica ... onics.pdf
