Hi all,
Can someone shed some light on how to send a number of Hex numbers with a space between, using network comms. been trying for some time and all i get is a load of single characters sent. I have attached what i have done.
Thanks,
Wayne M
Problem sending HEX numbers.
wayne_millard
- Has thanked: 1 time
- Been thanked: 9 times
- Has thanked: 616 times
- Been thanked: 814 times
Re: Problem sending HEX numbers.
Hi Wayne,
This seems to be behaving a bit better now. Note I have changed the startup loops a bit simply to allow the sim to run here without actually connecting.
wayne_millard
Thanks for the help i still have problem with what you have done please see attached. Thanks
Wayne M
Wayne M
Hi Wayne,
Aha I see, The data is just being sent as bytes but displayed as hex. Bear with and I'll change the example.
Edit. Here you go...
wayne_millard
