Problem sending HEX numbers.
wayne_millard
Has thanked: 1 time
Been thanked: 9 times
Post by wayne_millard »
Hi all,
Can someone shed some light on how to send a number of Hex numbers with a space between, using network comms. been trying for some time and all i get is a load of single characters sent. I have attached what i have done.
Flowcode1.fcsx
(24.31 KiB) Downloaded 463 times
Thanks,
Wayne M
Has thanked: 616 times
Been thanked: 814 times
Re: Problem sending HEX numbers.
Hi Wayne,
This seems to be behaving a bit better now. Note I have changed the startup loops a bit simply to allow the sim to run here without actually connecting.
Flowcode1.fcsx
(21.12 KiB) Downloaded 575 times
wayne_millard
Has thanked: 1 time
Hi Ben,
Thanks for the help i still have problem with what you have done please see attached.
Problem.docx
(3.67 MiB) Downloaded 553 times
Wayne M
Hi Wayne,
Aha I see, The data is just being sent as bytes but displayed as hex. Bear with and I'll change the example.
Edit. Here you go...
Flowcode1.fcsx
(15.84 KiB) Downloaded 560 times
wayne_millard
Has thanked: 1 time
Hi BenJ,
Thanks for the help you are a star.
Wayne :D
