Goodmorning Everyone,
I was doing a project earlier back before the summer starts with the Hc-Sr04. "NOW ITS NOT WORKING"
It's not compiling with Pics anymore.
I did some trouble shooting and found out that something is wrong with the Hc-SR04 Component.
Can you guys Check on it. Please and Thanks again.
regards.
HC-SR04 not working with ""Pic"" Anymore
daddytims_tims
- Has thanked: 125 times
- Been thanked: 13 times
- SR04_WaterProof.fcfx
- (11.28 KiB) Downloaded 388 times
jgu1
- Has thanked: 867 times
- Been thanked: 211 times
Re: HC-SR04 not working with ""Pic"" Anymore
Neither in Arduino
Br Jorgen
Br Jorgen
- SR04_WaterProofArduino.fcfx
- (11.13 KiB) Downloaded 363 times
- Has thanked: 752 times
- Been thanked: 811 times
Hi.
I have hopefully fixed the HC-SR04, but it won't be pushed on to the update system until next week.
To try the component.
Place the attached component.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsIf Flowcode is already open, then you will need to reload your project for the new component to work
- HC_SR04_Ultrasonic.fcpx
- (4.87 KiB) Downloaded 343 times
jgu1
Hi Martin!
Sorry not working. If I try to open one of my previus project with the UL sensor, it missing on the 2D board and the componentmacro is strange.
If I then add a new macro I get the screen as you see on the picure.
By the way Martin, your earlyer UL component has working perfectly, why does it suddently not working??
I have the proffesional licence?
Br jorgen
Br jorgen
- Skærmbillede 2024-08-22 153309.png (24.73 KiB) Viewed 10541 times
Hi Jorgen.
As all the components for FC10 are free, you should not be seeing that popup.
As a sanity check I have just used a free version of Flowocde v10: The modified component allows to be added OK and is compiling for me.
The only reason for seeing the pop up is when you try and add a component that was created for FC9 or below in to
Can you try readded the attached component to then reload, or close FC10 then reopen
Does anyone else also have the same issue?
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsThe main reason could be a child of the component has changed, casing a knock-on effect.
%ProgramData%\MatrixTSL\FlowcodeV10\ComponentsDoes anyone else also have the same issue?
- (4.87 KiB) Downloaded 346 times
jgu1
Well ok Martin. Normal I have no problem with opening a FC9 project in FC10. Something newer?
Still no luck with the new component. Now I get a new error.
Br Jorgen
Br Jorgen
- SR04_WaterProofArduino.msg.txt
- (5.89 KiB) Downloaded 336 times
- (11.66 KiB) Downloaded 348 times
The error is cause by the HC-SR04 pins being set to pins that don't exist
You need to change the pins from port A (as that does not exist within Arduino Uno) and select pins within port B, C or D
daddytims_tims
Hi Martin
I just tried. It still doesn't work. I copy the file to the folder updated it, try compiled but fail.
I restarted the win 11/ project It still fails.
I am using v10
I am using v10
- Screenshot 2024-08-22 103027.png (201.72 KiB) Viewed 10517 times
jgu1
I can compile now but the distance show random numbers.
- (11.66 KiB) Downloaded 336 times
