I'm running the latest version of FC10 Pro.
If I add the servo control component to an ESP project (ES32 S2 VROOM currently) it will fail to compile. I have configured the component in multiple ways, but without joy. The component seems to compile and run on other targets without issue.
Thanks,
MB
Servo Controller Component Causing ESP Compile Failure
nmjb18
- Has thanked: 10 times
- Been thanked: 1 time
- Has thanked: 756 times
- Been thanked: 819 times
Re: Servo Controller Component Causing ESP Compile Failure
Can you post your .fcfx, .c and msg.txt files and I will see if I can sport the cause.
If you want to keep your project private, then you can pm the files to me.
