Servo Controller Component Causing ESP Compile Failure
nmjb18
Has thanked: 10 times
Flowcode v10 Servo Controller Component Causing ESP Compile Failure
Post by nmjb18 »
I'm running the latest version of FC10 Pro.
If I add the servo control component to an ESP project (ES32 S2 VROOM currently) it will fail to compile. I have configured the component in multiple ways, but without joy. The component seems to compile and run on other targets without issue.
Thanks,
MB
nmjb18
Re: Servo Controller Component Causing ESP Compile Failure
Post by nmjb18 »
The problem also persists with the PWM component, displaying that: "#error MCPWM is not supported in this chip target"
Has thanked: 756 times
Been thanked: 819 times
Can you post your .fcfx, .c and msg.txt files and I will see if I can sport the cause.
If you want to keep your project private, then you can pm the files to me.
